It is currently Mon Nov 23, 2026 6:20 pm
 Post subject: Custom Font Trailing for Gimp 2.10 v0.2
PostPosted: Fri Jan 31, 2025 8:50 am  (#1)
Custom_Font_Trailing_v0_2_Tabbed.zip [18.05 KiB]
Downloaded 114 times
Unzip and install in your user plug-ins folder.
A pdf version of this guide:
Custom Font Trailing for Gimp 2.10 v0.2.pdf [1.27 MiB]
Downloaded 103 times
Please refer to the guide for the original release for the options not described here.
Link to original version
The new options are available mainly on Tab 1 and Tab 2 of the filter dialog.
Tab 1:
Use ‘Character spacing amount’ to adjust the distance between individual characters.
Default spacing:
Spacing set to 100:
Spacing set to -100:
Tab 2:
The new options on Tab 2 can be used to rotate individual characters.
Some text without rotation (note that the filter will now display a space character, that contains a glyph, correctly):
With character rotation set to 5 for all characters:
Use the toggle option if you want to rotate only alphanumeric characters:
Use the jitter option to set a random amount of rotation to each character; a jitter value of 40 would use random values of between -20 and +20:
And the effect applied to only alphanumeric characters:
Have fun!
 Post subject: Re: Custom Font Trailing for Gimp 2.10 v0.2
PostPosted: Fri Jan 31, 2025 12:01 pm  (#2)
Congrats Skinnyhouse for this new version of trailling. I'm sure I'll enjoy it a lot.
I did a quick test. It's so :coolthup
Thanks a lot. :tyspin
PostPosted: Sat Feb 01, 2025 1:09 am  (#3)
Thx Skinnyhouse. Appreciate the new features. :)
PostPosted: Sat Feb 01, 2025 3:32 am  (#4)
Thanks Issabella and Rod.
Glad you think it will be of use.
PostPosted: Sun Feb 02, 2025 4:29 am  (#5)
Much better having more options. :clap
PostPosted: Sun Feb 09, 2025 3:38 am  (#6)
PostPosted: Sun Feb 09, 2025 4:49 pm  (#7)
Love the curves Issabella.
:paint
PostPosted: Mon Feb 10, 2025 9:40 am  (#8)
Thank you so much. :)
PostPosted: Fri Feb 14, 2025 2:24 pm  (#9)
Using early version of a PreGiffer plug-in to take the results of Custom Font Trailing ready for export as a gif.
