It is currently Mon Nov 23, 2026 5:57 am
 Post subject: Is this a bug in GIMP 3.0 RC2
PostPosted: Mon Jan 27, 2025 3:40 am  (#1)
GIMP 2.10.38: When I select an area, and edit copy, the "Clipboard Image" pattern has the same size with the selection, as below image
But in GIMP 3.0 RC2 as below image, the size of the "Clipboard Image" pattern is almost the entire picture.
Sorry for my poor English, I use Google Translate.
There may be something wrong, Please understand.
GIMP 2.10.38 rev1 portable+GAP+G'MIC+nufraw+Beautify+MathMap+...
 Post subject: Re: Is this a bug in GIMP 3.0 RC2
PostPosted: Mon Jan 27, 2025 3:57 am  (#2)
... and if you press "ENTER" after dragging the rectangle before you copy?
PostPosted: Mon Jan 27, 2025 4:30 am  (#3)
It has been reported
https://gitlab.gnome.org/GNOME/gimp/-/issues/10046
and
https://gitlab.gnome.org/GNOME/gimp/-/issues/1635
No fix so far.
PostPosted: Mon Jan 27, 2025 11:15 pm  (#4)
rich2005 wrote:
OK, Got it, Thanks for your info.
PostPosted: Tue Jan 28, 2025 12:50 am  (#5)
Edit>Copy>Edit>Paste as brush works ( Tested in the newest Windows x64 installer commit).
Then you could just name the brush use it, and then just delete the brush if you didn't need it after one use. I know creating a selection and then Edit> copy should create the selection as a brush in the clipboard but this could be a work around for now.
PostPosted: Tue Jan 28, 2025 4:08 am  (#6)
That is a work-around for a brush, Paste as -> New Brush is there in Gimp 2.10 as well.
For Gimp 3.0 and a clipboard brush pair, another work around is, Paste as -> New Image then copy that and back to original image.
This a 30 second example: https://i.imgur.com/tNVdoeO.mp4
PostPosted: Tue Jan 28, 2025 8:58 am  (#7)
I'm not asking this because of the operation problem.
I'm asking this because beautify simple-border plugin requires this action
so I'll wait until this bug is fixed.
